topalsolucan
- 25 Mart 2010
full
yahu kaldır tüm oynatıcıları ve codec paketlerini.
Sana bir tek K lite codec pack yeter. İçerisinde Media player classic ile yapamayacağın ayar, açamayacağın video formatı yok.
https://daumpotplayer.com/potplayer-1-7-10667-x86-x64-stable/ dedi ki:What’s new in 1.7.10667?
Friends! Today there was an update, which we waited for 2 months. In this update, the developers made several additions and corrected the previous errors. For example, the ability to play MP4. You can see the full list of changes below.
- Added the ability to play MP4 streams
- Improved seeking speed with Built-in HTTP Async Reader
- Modified playlist handling to work asynchronously when possible
- Fixed a problem where playback of AVI files did not work properly
- Fixed an issue where codec-related settings were reset when switching presets
- Fixed a problem that causes the program to crash when Built-in D3D11 Video Renderer is used in Windows 8
- Fixed an issue where multiple color tags could not be read when subtitle time period is started from 0
- Fixed a problem that prevents playback of certain fragmented MP4 files
Download 1.7.10667
"Gerekli ayar dosyaları" ndan kastımız nedir ?elinde gerekli ayar dosyaları mevcut olan var mı acaba ?
@rise
reg dosyaları oluyordu hocam görüntü kalitesini daha da iyi seviyeye çekmek için."Gerekli ayar dosyaları" ndan kastımız nedir ?
Ben hiç gerek duymadım ve kullanmadım.reg dosyaları oluyordu hocam görüntü kalitesini daha da iyi seviyeye çekmek için.![]()
Version History of the PotPlayer
[1.7.13963] 2018/08/29
* Fixed a security problem (remediation of damaged audio files playback vulnerability)
- Fixed a problem where broadcast notification did not work in certain systems - Fixed a problem where album arts of certain MP3 were not shown - Fixed a problem where webm format was not created when capturing video - Fixed an issue that can't play certain blu-ray media - Fixed an issue where cover images of certain ogg files were not shown - Fixed a problem where cover image was not shown when playing seamlessly - Fixed a problem that browsed slowly when using online subtitle translation - Fixed a problem that screen did not come out when playing certain TS files - Fixed an issue where the program was killed when changing the video resolution under certain conditions - Fixed a bug of the built-in WASAPI audio renderer and improved it
