Valve Hammer Editör Hatası
memo0652
10 Ağu 2014
Mapi yaptım. Denemek için çalıştırdım. Cs açılıyor tam map dolarken kapanıyor oyun Acaba sorun nedir ?
Buyrun log dosyaları:
** Executing...
** Command: Change Directory
** Parameters: "C:\Program Files (x86)\Valve"
** Executing...
** Command: C:\PROGRA~1\windows\Oyunlar\Maps\zhlt\hlcsg.exe
** Parameters: "c:\program files (x86)\valve\cstrike\maps\jail_booz" -wadinclude scarty.wad
hlcsg 3.4 SSE 2 V2.0 (Mar 29 2009)
Zoner's Half-Life Compilation Tools -- Custom Build
Based on code modifications by Sean 'Zoner' Cavanaugh
Based on Valve's version, modified with permission.
Submit detailed bug reports to (amckern@yahoo.com)
----- BEGIN hlcsg -----
Command line: C:\PROGRA~1\windows\Oyunlar\Maps\zhlt\hlcsg.exe "c:\program files (x86)\valve\cstrike\maps\jail_booz"-wadinclude scarty.wad
Entering c:\program files (x86)\valve\cstrike\maps\jail_booz.map
Current hlcsg Settings
Name | Setting | Default
threads [ 4 ] [ Varies ]
verbose [ off ] [ off ]
log [ on ] [ on ]
developer [ 0 ] [ 0 ]
chart [ off ] [ off ]
estimate [ off ] [ off ]
max texture memory [ 4194304 ] [ 4194304 ]
max lighting memory [ 6291456 ] [ 6291456 ]
priority [ Normal ] [ Normal ]
noclip [ off ] [ off ]
null texture stripping[ on ] [ on ]
clipnode economy mode [ on ] [ on ]
clip hull type [ legacy ] [ legacy ]
onlyents [ off ] [ off ]
wadtextures [ on ] [ on ]
skyclip [ on ] [ on ]
hullfile [ None ] [ None ]
nullfile [ None ] [ None ]
min surface area [ 0.500 ] [ 0.500 ]
brush union threshold [ 0.000 ] [ 0.000 ]
Using mapfile wad configuration
Wadinclude list :
[zhlt.wad]
[scarty.wad]
8 brushes (totalling 48 sides) discarded from clipping hulls
CreateBrush:
10%...20%...30%...40%...50%...60%...70%...80%...90%... (0.02 seconds)
SetModelCenters:
CSGBrush:
10%...20%...30%...40%...50%...60%...70%...80%...90%... (0.11 seconds)
Using Wadfile: \program files (x86)\valve\valve\halflife.wad
- Contains 16 used textures, 39.02 percent of map (3116 textures in wad)
Using Wadfile: \program files (x86)\valve\cstrike\cstrike.wad
- Contains 0 used textures, 0.00 percent of map (123 textures in wad)
Including Wadfile: \program files (x86)\valve\cstrike\scarty.wad
- Warning: Larger than expected texture (348972 bytes): 'SNOW'
- Warning: Larger than expected texture (348972 bytes): 'SNOWWALL'
- Contains 24 used textures, 58.54 percent of map (439 textures in wad)
Using Wadfile: \program files (x86)\valve\cstrike\pka.wad
- Contains 1 used texture, 2.44 percent of map (1 textures in wad)
added 6 additional animating textures.
Texture usage is at 1.29 mb (of 4.00 mb MAX)
0.22 seconds elapsed
----- END hlcsg -----
** Executing...
** Command: C:\PROGRA~1\VALVEH~1.2\tools\VLUZAC~1\hlbsp.exe
hlbsp v3.4 VL30 (Nov 23 2012)
Submit detailed bug reports to (vluzacn@163.com)
----- BEGIN hlbsp -----
Command line: C:\PROGRA~1\VALVEH~1.2\tools\VLUZAC~1\hlbsp.exe "c:\program files (x86)\valve\cstrike\maps\jail_booz"
Arguments: "c:\program files (x86)\valve\cstrike\maps\jail_booz" -low -chart
Error: Can't open c:\program files (x86)\valve\cstrike\maps\jail_booz.b0
----- END hlbsp -----
** Executing...
** Command: C:\PROGRA~1\VALVEH~1.2\tools\VLUZAC~1\hlvis.exe
hlvis v3.4 VL30 (Nov 23 2012)
----- BEGIN hlvis -----
Command line: C:\PROGRA~1\VALVEH~1.2\tools\VLUZAC~1\hlvis.exe "c:\program files (x86)\valve\cstrike\maps\jail_booz"
>> There was a problem compiling the map.
>> Check the file c:\program files (x86)\valve\cstrike\maps\jail_booz.log for the cause.
----- END hlvis -----
** Executing...
** Command: C:\PROGRA~1\VALVEH~1.2\tools\VLUZAC~1\hlrad.exe
hlrad v3.4 VL30 (Nov 23 2012)
----- BEGIN hlrad -----
Command line: C:\PROGRA~1\VALVEH~1.2\tools\VLUZAC~1\hlrad.exe "c:\program files (x86)\valve\cstrike\maps\jail_booz"
----- END hlrad -----
** Executing...
** Command: Copy File
** Parameters: "c:\program files (x86)\valve\cstrike\maps\jail_booz.bsp" "C:\Program Files (x86)\Valve\cstrike\maps\jail_booz.bsp"
** Executing...
** Parameters: "c:\program files (x86)\valve\cstrike\maps\jail_booz.pts" "C:\Program Files (x86)\Valve\cstrike\maps\jail_booz.pts"
** Executing...
** Command: C:\PROGRA~2\Valve\hl.exe
** Parameters: +map "jail_booz" -game cstrike -dev -console +deathmatch 1
